twodownzero
Jan 27, 2019Explorer
profdant139 wrote:
Chum lee, by drilling and tapping, you do not mean self tapping, right? Do you mean using a tap and die set to accommodate a threaded bolt or machine screw?
Just trying to make sure I am on the same page with you.
Yes, that is what I meant. I would drill holes, use an actual tap to thread the hole, and install a bolt in the hole.
Sheet metal screws are for sheet metal. I have used self tapping screws before, but pretty much only where I can't either tap the hole or use a bolt and nut. No doubt they are more convenient, but they are also less secure.
Steel buildings are made out of sheet metal. No wonder they're put together with sheet metal screws.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
