TakingThe5th
Oct 31, 2018Explorer
westernrvparkowner wrote:hypoxia wrote:What are you running that regularly pulls a total of 100 amps? And what type of meter do you have that you can put it on the receptacle and it measures the amperage? It is my understanding that the only way to measure amperage is when you are actually drawing the power and I know of no easy way to draw exactly 50amps whenever you want to test a circuit.
I pull 50 amps from each leg on a regular basis and when I put my meter on the receptacle after he wires it it is a 240 VAC circuit with neutral and ground.
A Progressive EMS-HW50C will tell you what's being drawn on each leg. Add known loads to each leg and check the display. I like to turn on the two airs and other loads during set up to check the connections on the pedestal and beyond.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
