red31
May 20, 2017Explorer
Your quick connect is likely regulated low pressure propane, the same pressure that is used inside a grill. This means the grill's regulator needs to be removed and a quick connect plug added.
There are you tube videos, 'how tos' to do this for specific models of coleman grills.
https://www.youtube.com/watch?v=eQjjCwknAik
This does not work for a coleman propane stove since the stove's operating pressure is 15 psi, ie regulated high pressure, don't confuse regulated pressure with container pressure which varies widely based on temperature.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
