babamartha's avatar
babamartha
Fitting question
SO, I broke the door off of the fitting that encloses the power cord, so I ordered a replacement fitting online. I didn't realize until I took the old one off and tried the new one that the new one is smaller. I cleaned all the old caulk off, drilled three new holes, filled the old holes with silicone caulk, and installed the plate. I used a LOT of silicone between the plate and the camper.
I noticed that the original plate had foam insulation on it; the new one doesn't.
Have I made a bad decision in going ahead and installing the new piece? If I need to correct the situation, how should I go about it?
  • Nothing wrong with silicone, as long as you use a good quality neutral cure silicone and prep it correctly. Personally though I use Geocel Proflex RV or 3300 on vertical surfaces not contacting the roof membrane. I also always back up something like a cable hatch with butyl tape.
  • slavco wrote:
    babamartha wrote:
    All of this is good information. Thank you. I appreciate it.
    If you're going to re-do it, I would suggest using butyl tape as a gasket before you screw it back in. This will ensure water doesn't penetrate even if the sealant cracks at some point in the future.
    Thank you. I bought some just for this. I want a result I'm proud of.
  • Also you can't apply more silicone over old silicone, it won't stick. With silicone you will have to remove all the old caulk before you can reseal.
  • Silicone works well if the sun's UV rays cant get to it. Otherwise, it discolores and breaks quickly.
  • No. Everyone reccomend against using silicone for sealing on trailers. They all prefer dicor sealants as they hold up longer I believe. I think silicone breaks down easily with the sun
  • pianotuna wrote:
    Don't use silicone
    Why not? What are the cons? Are you saying I should uninstall the fitting and start over with something else?
