seatboard's avatar
seatboard
Quickee steps
2006 Fleetwood Revolution 40' LE. Here I go again with these quikee steps. sometimes they work, sometimes they don't. I can crawl under and hammer on the steps and whack the motor and sometimes, it works sometimes it don't. They can be inoperatitive and I can travel for a way, and when I stop and open the door, they are operating fine. It has become a case of holding my breath every time I open the door. I feel there is a loose connection or the contacts on the door are not touching. The small contacts at the lower left corner of the screen door are not making contact but I do not know what could have happened to the door. There are also, on the hinge side of the MH door two contacts. They are both made of copper and look like two Ball bearings half sumerged under the door material. two of these about an Inch apart, one on the door and the other on the frame. I am not sure what they are. They may be something to do with the remote door locks. It sure is tough being dummer "N a worm like me.:h
  • Hi, My 04 revolution steps. My steps extend but did not retract. The magnet relay at lower left of door was loose on the coach wall. Used a magnet to check if this was the problem with door open. Repaired loose mount, steps work fine now.
  • IF you can whack a KWIKEE motor with a hammer and it functions, the motor is bad. Replace the motor. It has a dead spot in the armature. Doug
  • I had similar problems with my Kwikee steps. I took the coach to a repair facility twice before they got them repaired. At least I thought they were repaired. I say thought because every once in a while they will not extend so my CEO/Navigator and I try to remember to look before we exit the coach.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
