Don___Carolyn's avatar
Jun 29, 2014
Radio/ CD - no power
Our Kenwood radio in our 2009 Arctic Fox 5th wheel does not turn on. We pulled out the radio and changed the fuse. We also changed the fuse in the fuse box. Still no power. We are hooked up to shore power and everything else works except the radio.
Any ideas on what else it could be?
Thanks,
Don
  • WE SOLVED THE PROBLEM! I remembered that I had turned off the switch for the speakers in the bedroom. As soon as I turned on that switch, the radio went on!! Ahhhh... nice music.
    Thanks,
    Don
  • you need to confirm that power is actually getting to the fuse. you need a test light or a volt meter. It may be that the radio has an internal problem. Also it may have lost ground, which is usually a black wire on radios. Good luck!
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
