trickyvic3
May 29, 2013Explorer
Re: 12v water pump acting up
Check all your fittings and make sure they are good and tight. Sounds to me like you have a slight pressure leak somewhere. It is normal for the pressure to drop some when running off the water pump with a faucet on, but when not running water it should hold pressure and your pump shouldn't run. At least ours doesn't.
