jrnymn7 wrote:
I'm all for the OP going with a 540w mppt system, if he plans to increase his boondocking, considerably. But then I'd also suggest a larger bank.
Now, I think if I went with four batterys I could stay out longer.
I want to run all the appliances for (limited time)seperatly except
the a/c unit.
I just need to find the space, and wire them in
(parallel 2-6v together) I want to know how you wire your appliances
to run off a inverter. does the inverter feed the panel while on solar
and then a transfer switch while on shore power?
Does someone have a schematic for something like this?
I will make sure size wise the panels will fit on the roof.
Sorry for all the questions, just getting started with solar.
Brian
