Moffittclan
May 16, 2016Explorer
I think I found the charging solenoid in the back of the battery compartment...
The right terminal comes from chassis battery and the left comes from the house battery. Here's what I get with a volt meter:
Right terminal (Chassis battery):
Engine off/no Gennie: 12.9
Engine on/no Gennie: 13.9
Engine on/Gennie on: 13.9
Engine off/Gennie on: 13.08
Left Terminal (house battery)
Engine off/no Gennie: 12.6
Engine on/no Gennie: 12.6
Engine on/Gennie on: 13.38
Engine off/Gennie on: 13.38
Another symptom, pushing the boost button on the dash doesn't seem to do anything. I tried putting it in "store mode" then turning on a light...nothing happened of course, but I thought if I pushed the boost button, I would see a light come on...nothing happened. Also, when I had bad chassis batteries a while back, the boost didn't do anything...
I can't find any blown fuses....does this mean that what I've found is in FACT the charging solenoid and based on these readings, it needs replaced?
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
