Moffittclan
May 17, 2016Explorer
Chris Bryant wrote:
That is the right solenoid. The only other test is voltage at the third small terminal- could have two small terminals, one would be ground then. That is an intermittent duty solenoid, but the controller cuts the hold voltage down, so you won't get full voltage at the small terminal all the time.
Small terminals had about .6 volts on each I think...might have to check again in the morning...what should it be?
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
