westend wrote:
Anytime the battery is connected to the 12 V system of the RV, there will be parasitic draws from the fridge, thermostat, water heater, radio, and alarms.
Sometimes, connecting the 120 V shore power and hence, powering the converter, will blow fuses or a circuit breaker to/inside the converter because of the high amperage draw of a depleted/bad battery.
How are you measuring the draw on the battery, with the onboard idiot lights or with a meter? If the former, get yourself a cheap multimeter, it will help you from not spending money on things you don't need. With your new meter, measure the voltage at the battery and at the converter output. Report back.
Measured with a multimeter. My manual makes no mention of battery cutout switch & seller never mentioned it. Now I just have to locate the little bugger & remove it. I guess I should just follow the leads. Can I expect to find it near the c/b & fuse panel? or do they like to hide it elsewhere?
