tvfrfireman
Jul 19, 2023Explorer
way2roll wrote:
I would guess a combination of a few things. An inch and a half isn't that much space. My guess would be your tires were hot and higher psi when you set up camp. After sitting, the lower temp/psi caused your entire rig to sit lower once down off the jacks. If that's the lowest spot, that's where the weight will shift and cause the largest drop. Like another poster said, you could have jacked it up, put a board or 2 under the nearest tire and set it back down. Standard board would buy you the 1-1/2" to drive off it.
Thanks for your response. I would have jacked it up and placed a board under the wheel but am concerned about where to jack. I am not an expert on these rigs and would hate to damage a vital part.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
