stingjra
Apr 18, 2016Explorer
dougrainer wrote:
If you see no leaks(probably not since the previous owner had the same problem), you have (depending on the brand of the slide system/pump), a solenoid at the pump leaking internally or the slide cylinder/s are leaking internally. It is also possible one of the electric solenoids AT the pump is not shut tight. They usually have a manual release on the solenoid. Your time frame points to a not tight solenoid. Most rooms that drift, takes 10 to 24 hours and usually only a few inches. Hyd rooms require constant pressure to stay open and retracted. How far does the room retract? Doug
Hi Doug
If this helps out any but I have to put the HWH hydraulics power up switch on at the front for my leveling jack for the rear bedroom slide to operate. The rear bedroom slide extends 12" out and will retract basic all the way in. I just put it out and 1 hour later it is retracted all the way in. Thanks
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
