Leatherneck2093
Jul 25, 2020Explorer
Garry&Gayle wrote:Leatherneck2093 wrote:Garry&Gayle wrote:
I had the same panel covering half the top vent on our Dometic RM1350 of which I cut to allow full vent flow. I then installed a 3rd fan in the back centered just above the factory fans along with triple vent fans inside, the thermistor should be on the left side wire is not very long. My fridge will run around 37 degs. and freezer is at 10 deg in 95 deg. heat. The eyebrow temp says 33-34 degs. the inside room temp will effect them also, try and keep below 80 deg. if possible.
Dometic told me not to add insulation to the very top of refer they need that air space.
Thanks for the info. I am able to keep our Reflection 28bh at 71 degrees easily with the 15k btu and the 13.5k btu AC’s. Was your baffle metal? If so how did you cut it?
I arranged my drain line to have a trap in it today and restarted the fridge at noon so the 2 hour defrost will happen in the middle of the night now. Don’t know how much affect that will have but why not. Every little bit helps.
The panel on mine was wood paneling which I cut easily with a hand saw, when you restarted your refer did you do a reset? or just off and then on again?
Just off for ten minutes then on. Didn’t know about a reset. Is that required and how is that done?
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
