Leatherneck2093
Jul 26, 2020Explorer
Garry&Gayle wrote:
I got this from Dometic Tech, and its also in the Dometic Technical manual; to do a reset turn off refer the cut all power 12V and 110V for a few seconds then turn on 110 and 12V turn on refer. the first defrost cycle will occur after 60 hours and then repeat every 48 hours there after.
Thanks for the information I will do this at noon today.
I added two Valterra fans in the bottom of the fridge yesterday. Prior to adding them the fridge was running between 39-43 degrees for the past several days. At 10pm last night the fridge was at 37 degrees and this morning it is at 33. I have not removed or modified the baffle yet. We’ll see how it does though the heat of the day. I haven't mounted them yet. When I do I will install switches in the fridge cabinet inside so they cant draw 12v when I don't want them to.
I also ordered 3 cooler guys120mmx25mm 105cfm 0.36 amp 42db IP67 12v fans on Amazon for $17.96 I will wire tie them to the top vent cover and put them on a switch. This should to help evacuate the heat. I’ll cut enough of the baffle away to allow the fans to fully function.
I am that this will resolve my issues.
Having RV issues? Connect with others who have been in your shoes.24,202 PostsLatest Activity: Feb 20, 2025
