kalia
Jul 21, 2018Explorer
Thank you to all who responded with actual help. We appreciate it. Yes, a/c is a Brisk II, we do have the model #s, but will identify the thermostat.
Sadly, we can't plug our unit in somewhere else as we live in a campground, each having our own 50 amp electric post. Also can't move the Bungelow park model.
To Doug: the unit will cool on hi/cool or low/cool. But because the fan is running, it takes a minute to realize that the compressor has shut down, blowing warmer air, and we can't tell if the compressor is humming because of the fan noise. One thermostat is in the unducted hallway across from a picture window. Brilliant planning on the trailer's manufacturer's part. We've been keeping that shade down. The bedroom thermostat is located across the room from the a/c. Will try all suggestions including the digital 120 voltage reading.
Thank you all again.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 05, 2026
