Gjac wrote:
Before you replace any more parts I would check the cooling unit first to see if it is good by discontenting the 120v heater from the board and connecting it directly to a 120v source and let it run overnight. If the refer cools down your unit is good and the problem is elsewhere. Let us know the results. Did you read the troubleshooting section that Old Biscuit posted?
Gjac, I double checked that there is 120v coming from the board to the heating element. Also, when disconnecting power to the board the burner lights immediately and will continue to burn. Would there be an advantage to connecting the heater directly to 120v?
Replacing the control board did correct the problem with the unit not lighting...but unfortunately its not cooling. We do have quite an issue with dirt dobbers and I'm wondering if there could be a blockage to the cooling unit.
I appreciate any input!
Thanks!
