2019 22rbswe with in command. Trailer has been in storage for the last month not being used. Outside temps have dropped to freezing in the morning. When I went to the command center to turn on lights...
I have found that it is a in command lock out issue when temp range is 40S or below or 90 and above. A problem with 2019 2020. Not sure if there is a fix
Having RV issues? Connect with others who have been in your shoes.24,246 PostsLatest Activity: May 13, 2025
