patriot1965's avatar
patriot1965
Solved
Electrical outlet issues
Hello all. Newcomer here. I have an electrical issue. I just purchased a Forest River Cardinal 3825FL. I had a couple guys helping me get it set up, plugged in, etc. To make a long story short, I dis...
  • MFL's avatar
    Jan 17, 2024
    To start, would be to disconnect the improper power source. Next, you'll need a qualified electrician to check/repair all electrical in your coach, to ensure all is safe for future use. You mentioned several appliances were toast, and you're likely correct. All needs to be checked!
    You are not the first, that this happened to. It is not good. but can be repaired.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
