weschaney
May 13, 2017Explorer
Jim, it bogs and bucks, in neutral i can control the rpm fine, only when under load (in drive) it starts to buck and bog. The more research i do I'm finding a difference between fuel pressure and fuel volume. in some instances you can have good pressure, but the pump can be so clogged the volume is compensated thus starving the engine of fuel. kinda weird and hurts my head. I plan on testing the pressure while driving today. Thank you for the info.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
