Gerald55
May 07, 2016Explorer
Right, I'm planning on using all four fans to promote a good bottom to top flow, two in-between the vents, and two on the top vent to expel the hot air.
I still kind of need to know what need to be cooled though, since it affects fan placement and baffling. In particular, the condenser fins at the top are poorly barffled and tend to be hot because they are located right at the top of the top vent. Fixing that requires some work. Work I want to avoid if what needs to be cooled is the condenser coils.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
