Gerald55
May 08, 2016Explorer
Chris Bryant wrote:
The top condensor fins are the most critical. The more liquid ammonia you can condense out the more cooling you will have. The absorber coils do reject some heat, but that is not their real function.
The unit should be baffled so that all of the air must pass over the condensor.
Thanks! My fridge does have baffling, but it is focused on the absorber and stops before the condenser fins, so air can indeed avoid the absorber unit. I'll fix that.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
