Drew_A_
May 24, 2021Explorer
OP here. Thanks everyone for the good info. I will definitely be adding to the condenser side fans before looking into inside evaporator fans. I have not even had the chance to look into the upper outside compartment yet. I'll be doing that soon.
One thing I just noticed is that the thermistor on the fins can be moved up/down just like on fridges that do not have temperature control settings. Is moving the thermistor up on the fin something I should try? Moving the thermistor is not mentioned in the Dometic manual.
thanks
thanks
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
