indianbones
May 15, 2018Explorer
RLS7201 wrote:
Not sure what Fleetwood installed on the 2000 Flair. You should either have this self latching relay to disconnect your batteries or this self latching relay............
Richard
The second one is identical to the one that the coach battery is hooked up to. Which I believe would work with what I am trying to do.
I have seen the first one but I'm pressed on time and had to order one that would hopefully work and has had some feed back for similar use. I chose a cheaper one that I don't expect to put a heavy load on just need to be able to run the lights at night and the pilot light for the fridge. From what I have gathered I dont need a heavy duty one and I am willing to roll the dice. My main intention for this is to see if this is where my problem is.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
