lt1tyrell
Jul 03, 2015Explorer
MEXICOWANDERER wrote:
Be sure it's the element gone bad. Most heat chambers are 2 feet above the base buried in fibergkass whuch is under thin galvanized sheet metal. Use nitrile gloves and goggles or risk a trip to an opthomologist to get fiberglass fibers get dug out of your corneas. Follow the pair of fiberglass insulated wires to the element.
Ok thank you, the code says ac heater failed so I checked the fuses under the little cover that has the circuit board inside...unfortunately the fuses were good.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
