pianotuna
Sep 12, 2021Nomad III
Re: Inverter cooling fan
S Davis
What is the wattage of the inverter? What is the efficiency?
For example 1000 watts at 9% = 111 watts of heat to dissipate.
From that you could calculate the air flow needed.
I would use DC computer fans, one to exhaust and one to blow into the box.
I'd use a mechanical thermostat to control the on/off cycling.
My Magnum caught on fire--because it uses AC controls (or perhaps AC fans).
