Re: LCI slide control
Remove the 2 screws that hold the wall switch. Extend the room and then unplug the harness from the wall switch. LEAVE for as many days as you can with the unit plugged in. IF the room still retracts you need a new Control module(not the wall switch). This should be the module and system. Doug
https://lci-support-doc.s3.amazonaws.com/manuals/slideouts/powergearslideouts/3010002088_m_sq_installation_without_room_locks_rev_oc_lr.pdf
