MELM
May 09, 2008Explorer
heavyequipmentmover started a new thread. But I'm moving the post to this one and closing it - one thread is preferred. Mel
heavyequiptmentmover wrote:
I called Dometic today to confirm that my Dometic RM 2652 refer is included in the recent extention of recalls. (888-446-5157) Other than tell you your refer is one of the recalls,the young clerk at that number is not any help on details of the necessary work to comply with the recall.
Also called Dometic customer support 574-294-2511 thinking I would be able to get more information on the work necessary to accomplish the recall.The young man there was no more help then the previous young lady.Even though he said he was there to answer Tech questions,was not willing to give out info on the recall.
The NHTSA letter to Dometic of April 21,2008 stated that Dometic would install a secondary burner housing.I am not familiar with the nomenclature BURNER HOUSING.Is it referring to the cylindrical tube that surrounds the flue tube and electrical 115VAC heater?
If the recall installs a secondary burner housing within a burner housing,how does this effect the efficiency of the burner?
I have noticed that Dometic has installed a thermofuse on the cylindrical tube that surrounds the flue,whos location is in series with the 12+VDC to the Control Board.Is this Dometics means of killing power to the control board,to shut down burner incases where things get too hot within the cylindrical tube.Like if you have an uncontrolled fire?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
