all4coop
Jun 05, 2017Explorer
I have good 120 volt power at plug both where it plugs in and at the plug ins throughout the trailer/
With battery disconnected the lights are dim and i checked the voltage by pulling a bulb out and it was 8 volts there.
I recharged my battery and reinstalled it and lights were bright but AC compressor did not start ( again the smaller starter compacitor is bad so I just have it unhooked, not sure it has to have it to start or not, my hvac go to man said it should start without it)
I hear no fan noise like I use to at the converter.
I checked the voltage at where the pos/neg are located I think coming out of the convertor. I says positive and negative on the board and its 10 volts there to.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
