TLLOYD's avatar
TLLOYD
Re-packing bearings
I have a 2007 Fuzion fifth wheel and paid $125 per axle (X3 axles) 2 years ago to have the bearings serviced. I can't see paying that again when it seems easy enough to do it myself.
I took the tire and hub off to get a look at it. Was easy enough to get castle nut, washers and bearings out. It all looked good and still had red bearing grease. I don't take it out much.
Question I have is that there is a zerk fitting on the end of the axle shaft. I assume this if for maintenance purposes for pumping in some grease before trips? The bearings and end cap had a good amount of grease in/on them, but the cavity between the inner and outer bearings did not.
After I repack the bearings, do I need to pump grease into the zerk fitting? If so, how much and does the cavity between the bearing need to be filled? I am asuuming not because it wasn't after I had it serviced at the shop, but I want to make sure I do it the right way before my next trip.
It would take a lot of grease to fill that cavity and the only way to know it is full is when the grease comes out of the outer bearing.
How often should I be re-packing the bearings?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
