WA4HTZ
Oct 23, 2018Explorer
I know this is a somewhat old thread but since there seems to be a bit of contention about the O2cool fans, I thought I would post actual measured test results on one of my fans. Using a bench power supply set to 13.6 volts (changing the output requires taking the supply apart so it stays at 13.6), I measured 610 mA on high and 450 mA on low. At 12.6 volts these current draws would be lower since the fan uses a permanent magnet DC motor. The coaxial power connector on the side of the fan takes a 5mm O.D x 2.1mm I.D. plug if you want to make your own cable to plug into your RV. Hope this helps some folks who would like to use an O2cool. BTW, these results are for the 10" fan.
Ken
Ken
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
