bobvilaExplorerAug 22, 2024San-T-Flush outside inlet broken Hello, My San-T-Flush port is broken and there water leaking outside, when I used. Looks easy to remplace. I strugle to find out in Canada the same part. I checked in You-Tube and found-out that so...Show More
bid_timeNavigator to bobvilaAug 24, 2024Well r3moving the check valve was probably not the best thing to do. It is a health safety device.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
Related ContentNo power on outside GFCI outletSan T FlushSan-T-Flush not flushingBlack Water Tank San-T- Flush Vacuum Braker LeakSan-T-Flush Pre-Tank Leak
