jconnally
Jun 29, 2014Explorer
Based on 11.2 amps it sounds like you want to run an A/C. If that's the case search for Honda EU2000 A/C. You'll see numerous threads discussing start amps required and efficiency loss when it is hot. Some folks can run a 13.5 A/C on a single Honda EU2000 but most folks can't. I can start a 13.5 A/C and run but if it's above 90 degrees (when you really need the A/C) after about 10-15 minutes I can see the voltage start dropping and then it goes into overload. That's why I have 2 paralleled.
The Yamaha 2800 will run an A/C no problem as will the Honda EU3000. Anything less is iffy.....
Joe
Joe
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
