Fire_Instructor
May 22, 2018Explorer
On a previous unit, I had basement doors that had no locks. The foam material was inadequate to secure locks to, so I removed the doors, carefully scraped most of the foam material from the back side of the door, and cut and glued a piece of plywood in place of the foam. I made sure that the hinge screws went into the plywood by using a much longer screw, so that the door was properly supported. Can’t remember if it was 5/8” or 3/4” ply.... I had that unit for another 7or 8 years, and it was still fine when I traded it. A benefit was that I was able to screw storage clips to the back side of the doors to store small items like the stabilizer crank and the 30 to 15 amp adapter....
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
