BruceMc
Sep 27, 2018Explorer III
Storage compartment pans sagging, separating from sidewalls
Our 3 year old Sunseeker has compartment pans that are too thin and light, and had too few anchors to the outside sidewall. Our 2000 Four Winds has a pass-through compartment with a one-piece plastic pan, and after 19 years, it shows no signs of sagging.
Too bad Forest River's bean counters cheapened things down to this point, but that's the way it is, bean counters being what they are.
As the pans started sagging, they pulled the pan lips away from the outer sidewall. Note the gap between the pan and the outer sidewall, at the bottom of the image:
Rather than simply add more screws to the lip, I decided to create some braces to bring the base back to level and to provide better support. I had some 1/2" angle iron and fittings from an old crib, so this is what I built:
Installation details: outer end:
Inner end, tied to frame rail:
Outer end bracket extends just above the lip inside of the compartment, I cut just a bit of pan material down to install two self-tapping screws. I took this image after spreading sealant in the gap, then after installing the remainder of the screws, I spread sealant on the screw heads:
After the initial fitting the brackets, I painted the complete bracket with paint I'd squirreled away in the chemical locker, heck, they'll get dirty soon and will look like the remainder of the underside of the coach:
Once I have the brackets in place, I'll cut some 3/16" plywood to fit the inside dimensions of the pan to provide additional support.
I have 3 compartments on our Sunseeker 2250, I suspect others have several more on their units, all with similar issues. I have these issues with the rear two compartments. The forward compartment just behind the rear door appears to be fine, though I'll add a few more screws to ensure it stays in place over time.
[/img]
[/img][img]
[/img]
