images
Sep 13, 2018Explorer
I have drilled a lot of stainless and found a small brad point drill bit worked best for the pilot hole.
And don't forget stainless work hardens so you want to use sharp tools and a coolant, if you are tapping or cutting threads don't let it heat up go slow and easy.
If you use a dull drill and the stainless work hardens your in for a really big hassle.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
