mvas
Jul 06, 2017Explorer
With only 5 - 6 Hours of Full-Sun (equiv) per day, charging a deeply discharged Lead Acid battery back to 100% SOC, between sunrise & sunset is very difficult. So, increase the voltage that determines when we change from Bulk Mode to Absorb Mode.
Staying in Bulk Mode longer
a) Puts more AH into the battery faster
b) Decreases the time needed for Absorb Mode significantly
c) Uses more water
d) Causes more Grid Corrosion
e) Increases chance of 100% SOC by sunset possible
Is PSOC the #1 reason for early battery failure?
c) Uses more water
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
