I have a 2014 wild wood 26 ft travel trailer and I'm trying to figure out how to adjust the hot water heater. The water is warm at the best. I checked the valves and the cold water valve is closed. Is...
Thanks for all the replies I checked the relief valve outside and that water is hot!! It has to be mixing somewhere I've just to find it . I'm going to re check the valves at the tank and make sure they are fully closed
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
