allenm
Mar 01, 2018Explorer
I can confirm that water pressure too high in campground can cause a good check valve in water pump to leak water into the fresh water tank, as well as cause toilet to leak water into black water tank. Solution - install a good water pressure regulator, the kind with a gauge. In my case, the campground pressure was running around 100 lbs, but only sometimes.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
