joe6789
Nov 03, 2019Explorer
I'm back with a follow-up question, this time about the DC side.
I'm seeing my DC voltage drop to 1 or 2 volts when I've hooked up both the Victron inverter/charger and the DC loads, with all AC wiring completely disconnected. Specifically, positive terminal of battery has one wire going to the inverter/charger positive and one wire going to the positive bus bar, while similarly the negative terminal of the battery has one wire to the inverter/charger negative and one wire to the negative bus bar. Neither the inverter/charger nor the DC loads function when both are connected, since 1 to 2 volts is too low.
Battery is fully charged. I see 13V when I disconnect the inverter/charger and only connect the DC loads (e.g. lights). Likewise, I see 13V when I disconnect the DC loads and only connect the inverter/charger. But when BOTH the DC loads and inverter/charger are connected, the voltage across the positive and negative sides drops to 1 to 2 volts.
Any ideas what's wrong?
I'm thinking it's related the inverter being grounded to chassis and the negative bus bar for the DC loads also being grounded to chassis. Note I have not yet hooked up any AC wiring to the inverter/charger, so the issue must be contained on the DC side.
Again, would appreciate if others with more experience could chime in.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 07, 2026
