SteveAE
Aug 29, 2013Explorer
Rbertalotto,
That is unfortunate as it works great with my Sunsaver. Different model I guess.
You could monitor solar output voltage via the B2 switch on the Trimetric (I do this as it's faster than navigating through the Morningstar Remote menu)
To measure solar panel current you could put a second Trimetric shunt resistor in series with the solar panels, and then measure the voltage across the shunt to determine panel current (current = volts/resistance).
Steve
Steve
