bigfinkExplorerAug 19, 2014rear axle tire wearI have a rear axle tire wear problem. The passenger side rear axle has excessive inside wear, driver side has same pattern but not as bad. What causes this howdoI fix it
Old-BiscuitExplorer IIIAug 19, 2014Could be from overloaded, bent axle, bad spindle, alignment, spring hanger, loose bolts..........
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
Related ContentAxle and tire?Tire/Axle Questionrear axle gear ratioFreightliner Rear Axle Hubcap RemovalRear Axle Weight
