bigfinkExplorerAug 19, 2014rear axle tire wearI have a rear axle tire wear problem. The passenger side rear axle has excessive inside wear, driver side has same pattern but not as bad. What causes this howdoI fix it
Old-BiscuitExplorer IIIAug 19, 2014Bent axle, bad spindle, alignment, broken shackle, loose bolts etc
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
Related ContentAxle and tire?Tire/Axle Questionrear axle gear ratioFreightliner Rear Axle Hubcap RemovalRear Axle Weight
