I have a rear axle tire wear problem. The passenger side rear axle has excessive inside wear, driver side has same pattern but not as bad. What causes this howdoI fix it
Both the wheels on that axle are not pointed in the same direction. Oh yeah, you probably knew that,:))) so when did this start, right after you hit something ? Or it this RV new to you ?? Etc etc.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
