theoldwizard1
Apr 06, 2020Explorer II
BobsYourUncle wrote:
If your valves seating properly is an issue, or you think it's an issue, you could try "lapping" them.
If it is a part, you might a well "lap" the valves. Several videos on YouTube on how to do it (this procedure is NOT engine specific, just don't go crazy; it only takes a little).
I don't know if that engine has a compression release (typically a mechanism that will hold the exhaust valve open slightly longer). You need to disable it and do a compression test. You should be get around 100 psi.
As you are re-assembling, check to make sure you are getting spark.
The old saying is "you need fuel, air and spark", but you also need compression and they all have to happen AT THE RIGHT TIME !
Good luck, keep us posted.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
