groundhogy's avatar
groundhogy
Rebuilding my eu2000i... (never did this before)
My generator stopped working and I had it to three shops. One got it working and after ten hours, it died (he said he decarbonized). The second two guys couldn't get it running. So I thought it must be something deep inside wrong.
So I pulled the whole thing apart. Labeled things and put them in baggies. Took pics as I disassembled.
I am now examining the parts. I found an old GX-100 shop manual online. This has the specs on things like valves, piston wear dimensions, etc.
I have zero experience, but, having said that, it doesn't look to bad inside. Like I can still see the machining lines on the piston. You know where the cutter went over it?
The valves look somewhat suspect. I did wiggle the valves in the guides and the Intake is tight. The exhaust wiggles a bit more. There is some carbon around the edges of the valve seats. The valve doesn't look like a nice 45 degree flat either. It's kind of cupped where it touches the seat. But I have not cleaned the valves yet, so that might be an illusion with the crud.
I am trying to find this big defect that prevented the motor from running, but it is not sticking out at me.
Could the valve carbon have caused decompression?
I do remember at the end, when it did run, it had lost power.
Any comments or big belly laughs weclome. lol.
  • Three things are important - compression, spark and fuel. Even if they don't arrive when they should, it should at least backfire if they're all present. You should have checked the compression before you took it apart. Did it have a good hot spark? Was the plug wet with gasoline?
  • So, say if I order a new cylinder and two valves.
    Will they mate perfectly out of the box?
    Also, will the valve guides be already pressed into the new cylinder?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
