wa8yxm
Mar 23, 2016Explorer III
Testing a GFCI means that you apply a very high resistance between hot and ground (Specific amount) so that a very low current imbalance is created, IF this results in teh CLICK OF DARKNESS (Trips the GFCI) then it is good.
if not, not good
My tester has a GFCI test button so it does not trip the GFCI till I instruct it to. Works too.
Note. I suspect some outlet 3-light testers, the 2nd Green (Hot-Ground) draws enough current to trip a GFCI at least some models.. Again, this indicates GFCI is working very well.
if not, not good
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
