wa8yxm
Dec 31, 2013Explorer III
The Sears unit I use is a 82-369.
A recent discussion on these meters one "Expert" Said that they were of little if any use to an RVer,,, this was less than 24 hours after this meter diagnosed a bad battery and not only that but which of 4 batteries was bad... I used the clamp on function to find the bad battery..
So I'd have to argue with said "Expert" Cause it sure saved me a bunch of work.
The one "Complaint" or issue I do have is that on DC they read "Absolute(amps)" That is they can not tell charging current from discharging current on the battery.
A small magnetic compass might help there. If you know which hand to rule it with (I forget and have to look it up)
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 22, 2026
