Canadian_Rainbi
Jul 25, 2015Explorer
I've investigated almost every option. There is NO room in the battery compartment and little enough in the bay next to it which is located UNDER a slide. Beside which, the BlueSky is a bulkhead (set into a hollow wall) and would need make mounting brackets but even then it would not be easy to get at in order to see what it was doing or to make any adjustments. (The electrical bay is under the slide.)
Anything with a remote battery voltage sense would take care of the problem with little if any loss of charging efficiency over one placed next to the batteries.
Also, I have been tempted for several years to add more solar panels and the BlueSkye is maxed out with the 420 Watts that I have already.
