Canadian_Rainbi
Sep 23, 2015Explorer
JiminDenver wrote:
I think you will like the TriStar. It has everything you listed as needs. I'd make sure it has plenty of ventilation because when it gets going for a while, it can put out some heat.
That (heat) is about my only concern. It will be in a busy and small compartment, sharing space with the Xantrex Prosine 2.0 inverter. I'll probably end up leaving the compartment door open when we're parked, and when we're driving it shouldn't be running too much. Also, for now, it won't be getting much over 20 Amps.
Here is where it will be going:
